Originally Posted By: tig1
I do the turkey baster method every engine oil change with the brake fluid and the PS pump. This has worked well for me for many years.
The problem with that is that brake fluid absorbs moisture from the air. Water is heavier than brake fluid, so any moisture will settle to the bottom of the system over time, which would be your calipers or wheel cylinders. Just changing out the fluid in the master cylinder won't do anything to get the moisture contaminated fluid out of the calipers, you need to open a bleeder and remove the old fluid.
