Brake Drum Bolt Size
The Tropical Fine City
Guys, Anyone know what size is the bolt that you insert into the drum to pop off the stick drum for a 2006 corolla? It's got a little rust on the threads but it will chase without a problem If I insert in the right size bolt.
I think it's 8x1.25 but I am not sure and I don't want to run it down if it's the wrong size.
The factory manual does not specify the bolt size for this.
Thanks.
Import cars don't go for too much variation. 8 X 1.25, if that's too big then it's 6 X 1.0
edit: I mis-read, I thought you was looking for wheel cylinder bolts. Yes 8 X 1.25 to get drums off.
