Chemical analysis of Dexcool has proven that Dexcool when exposed to air pockets in the cooling system reacts with the cast iron parts(hence the rusty color) It has nothing to do with mixing with other coolants. The manufacturer literature states that the coolants can be mixed but the long-life properties are shortened.
As long as Dexcool isn't exposed to air, it doesn't give problems. That is the real trick however, when the intake manifold gaskets fail and allow air in the system. The active ingredient 2EHA is a plastisizer and will degrade some types of plastic gaskets. The reason this site is here is to share facts, not hearsay, do some research people.
If you are dedicated about the facts, not rumors, do more research on 2EHA. The claims about it softening plastic are not substantiated.
So, is that why VW, BMW, Mercedes, Chrysler, and Ford rejected Dexcool? Because it doesn't degrade plactic parts? If not, then why did they reject Dexcool? They all tried it and decided not to use it. Who said it doesn't degrade plastic? GM? Havoline? Chemical analysis proves out that it does degrade certain types of plastic and it is a plastisizer or GM woukdn't have had to change their intake manifold gaskets that didn't cause problems with green antifreeze and did with Dexcool. What is a simpler explanation? Dexcool damages plastic gaskets? or GM just started making inferior gaskets at precisely the same time they started using Dexcool? For those of you who refuse to use anything but Dexcool, nothing I say is going to matter, but for those of you that are willing to look at both sides of the coin maybe this makes sense. Keep on draining Dexcool every 2 or 3 years to try to be safe or use another coolant that actaully is long-life and will last 5 yrs or 100,000 miles like G-O5. If you are going to drain it that often, why not use green antifreeze. It lasts that long, and it doesn't turn to brown sludge when exposed to air, and it doesn't harm gaskets.
Do you have any studies or analysis that can back up your claims?
They say a picture is worth a thousand words, so here ya go:
http://www.zillamotorsports.com/DEX/
Notice in the pictures that there is no problems with the gasket except where the Dexcool made contact with the gasket and also notice the low mileage at which the damage had occurred. If this doesn't convince the doubters, then they must work for Havoline or GM.
