I've replaced one of my downstream sensors 3X and the other downstream sensor once. 2002 Dodge LH. I can watch the data stream - both sensors are running high but not steady. generally .65 - .85 and normally staying closer to .85 than not. so... bad conincidence or a wiring problem? BTW - both upstream sensors are bouncing numbers correctly from .15 - .95
