The differential is absolutely the same as the M-cars; per BMW technician training documents (which I have spent hours before reading in the BMW TIS — technical information system) (no ///Marketing or other crap; these documents MUST be accurate or a technician could get hurt, and that opens up to lawsuits, etc). The only difference is 1 extra clutch in the pack. Even the servo motor and control module ("GHAS") is the same. Note: the GHAS only handles locking the differential. It doesn't directly control when it will lock, with regards to vehicle dynamics.My XDrive car is doing almost everything a RWD M2 would do (except for when the t case kicks in during a drift and it becomes a little sketchy - so this mostly applies to parking lot shenanigans). The diff for the most part, is almost the same.I'm not going to dispute your data, but the LSDs are not the same. I've seen both off the car. They may be the same type of LSD but who knows what is different internally and I'm not even sure the vendor is the same. The M units are derivatives of the GKN that came on the F90 M5.
With your front diff, you have probably set yourself up for a tough situation. I'd make it look like you never changed fluids and drive until it fails unless you're good buddies with your SA. Unless you can demonstrate a problem like noises you'll just make them suspicious and think you're crazy if you tell them you had elevated wear metals.
I don't have access to the technical service documents to post here, but if you wanted to validate it, it can be found here: https://bmwtechinfo.bmwgroup.com/#/login
edit: there may have been a misunderstanding. When I said "they are the same diff" in the OP, I was referring to the rear. Front diff and the t case system is entirely different from AWD/RWD switchable M cars. I forgot what the difference is, but they are absolutely not the same.
