This is the label on the top of my BMW 535d battery. Any idea what the difference is between the "A:" & "S:" numbers?
What I mean is what is the difference between the AW & S numbers? They both look like part numbers.Looks like a BMW part no.
Supposedly, it's to ensure that the car’s onboard computer recognizes the new battery and optimizes the charging system accordingly....for Pete's sake why does a car companies feel the need to have a tool to program a vehicle for a new battery?
I edited my comment. New vs old pn. I bet one is no longer available.What I mean is what is the difference between the AW & S numbers? They both look like part numbers.
That's correct, but a lot of people - primarily those that don't and have never owned a BMW - always feel the need to point this out.Supposedly, it's to ensure that the car’s onboard computer recognizes the new battery and optimizes the charging system accordingly.
There's a charging algorithm which adjusts based on the age and type of the battery. The older the battery the greater the charge from the alternator.From bmw forums it's either cca related or lead acid vs agm battery. I've always liked BMW's but for Pete's sake why does a car companies feel the need to have a tool to program a vehicle for a new battery?
My concern is I am an outlier. I have an almost six year old M550iX that has less than 15,000 miles and both factory AGM BMW batteries are constantly on a Battery Minder battery tender when parked in my garage. Both batteries load test "as new"...so is the IBS (intelligent battery sensor) just assuming since the batteries are 6 years old to charge them accordingly like a typical battery that gets zero care and never seen a battery tender? If so, I suspect they are getting overcharged when I am driving around.There's a charging algorithm which adjusts based on the age and type of the battery. The older the battery the greater the charge from the alternator.
The IBS won't overcharge, I still have the factory battery on my 2015 (2014 build date) and although it has been on a maintainer since COVID it has aged to the point that my blend doors loose their calibrated state.My concern is I am an outlier. I have an almost six year old M550iX that has less than 15,000 miles and both factory AGM BMW batteries are constantly on a Battery Minder battery tender when parked in my garage. Both batteries load test "as new"...so is the IBS (intelligent battery sensor) just assuming since the batteries are 6 years old to charge them accordingly like a typical battery that gets zero care and never seen a battery tender? If so, I suspect they are getting overcharged when I am driving around.
I've been tempted to reset the IBS for a new battery installed, but so far, have just left it alone.
The Bimmer batteries are always oversized and more of industrial tge last few I saw at local car meets. And many Bimmers have 2 batteries even for the 3 series.That's correct, but a lot of people - primarily those that don't and have never owned a BMW - always feel the need to point this out.
It does seem excessive, but it also seems to help the batteries last longer. The original battery in my E90 lasted either 9 or 10 years, so that's a pretty good run.
The BMW battery registration process is only required in order to reset the battery charging parameters back to zero, or new.The Bimmer batteries are always oversized and more of industrial tge last few I saw at local car meets. And many Bimmers have 2 batteries even for the 3 series.
But I am not sure any other makers require battery registration to even turn the car on. Many people got stranded after being lucky enough to find the right batter my size but the cars won’t start. Some was smart enough to find a YT solution if disconnecting a green connector to bypass.
