- Joined
- Jan 29, 2022
- Messages
- 241
Has anyone ever used this? What’s it made of? How does it work?
My 2001 chevy blazer 4.3 Vortec with 103k miles had a timing cover leak. It was never enough to actually leave drips on the ground, but the bottom left corner of the timing cover was leaking. I tried tightening the bottom left bolt a little to see if that would help but it did not. Timing cover is the only thing that’s leaking.
So I was doing some research to find the best additive that can potentially save me from taking off the oil pan to replace the timing cover, then I saw this thing called “Rear main sealer” made by Blue Devil. Saw great reviews on the internet, so I decided to try it out. Believe it or not, this thing actually fixed my timing cover leak. $15 at Walmart for a bottle that can treat upto 8 quarts of oil. It’s clear liquid.
I washed the timing cover area really good with degreaser, and then I added this chemical into the engine and drove around for 3 days (regular commute to work and errands around town) and this morning I checked under the car and there is zero leak, bone dry except a little bit of dried up oil drip on the bottom of the cover and the front main seal which was probably leaking on the first day of using this additive. But this blue devil fixed my oil leak in just 3 days.
i don’t think this sealer from blue devil is snake oil. It worked great for me. Give it a try.
I heard this stuff is supposed to swell rubbers, but I just wanna know what it really is made of. If anybody knows, please let me know.
