Whew, I'm not the only one...
I have a 1974 Triumph TR6 (41,000mi) w/ the Aeroquip/Mocal spin on fliter coversion that, with an ADV equipped filter, should shorten pump up time. Certain Triumph engines are known for their "death rattle" when started and before oil presure builds. To minimize this I crank w/o choke until I get presure then feed in choke to start.
I threw out the Fram that the seller threw in w/ the kit and used an Mobil 1 filter (Mobil 1 204 if I remember) and it still took what I though was too long to register oil pressure while cranking; ~10 sec vs. 15+ for the original cartridge.
I tried the "blow" test (Wife thought I went over the edge) and it would not hold air. Unsatisfied I located the appropriate Mann & Hummel filter, repeated the "blow" test and it held, completely. I changed the oil (Mobil 1 MX4T 10W-40 syn) and cranked the engine w/o choke and got pressure at 5-7 seconds, repeatedly. I bought a case of the Mann's.
Anecdotal and certainly unscientific but....
Thoughts anyone?
Regards, W&w
