quote:
Originally posted by Fuelrod:
Engine braking is not effected by throttle position..Throttle open or closed, makes no difference. "Pumping losses" increase dramaticly as RPM increases, caused soley by reciprocating mass...
Now, would you like to talk about Jake Brakes??
Yes, engine braking IS affected by throttle position.
In Ford vehicles, the idle air control valve (which is a bypass around the throttle) is fully open when the throttle is open.
When the throttle closes, the fuel is turned off and the idle air control valve closes slowly to gradually increase engine braking. This prevents what Ford calls "lift throttle snatch"..in other words, they want the vehicle to decelerate in a smoother fashion than would be the case if the throttle just slammed shut.
As far as Jake Brakes, here is what one site has to say about how they work.
http://www.straightdope.com/mailbag/mjake.html
"The jake brake slightly opens the exhaust valves when the piston is near top dead center (where ignition normally occurs). On the upstroke, the piston compresses the air in the cylinder to 1/15th its original volume. This creates a lot of drag on the engine. The Jacobs Engine Brake then releases the compressed air, and the energy stored in it,
before it can push back on the piston during the downstroke."
Opening the exhaust valve and dumping the compressed air is KEY to the operation of a Jake Brake.
Otherwise, what I've put in bold will happen, and greatly reduce if not eliminate the engine braking effect. This is what happens in a gasoline engine.
Put another way, the energy used to compress the air isn't wasted. It's stored for a short period of time (as potential energy), and unless dumped, will push back on the piston with a force equal to what the piston compressed the air.
More about Jake Brakes:
http://www.bankspower.com/tech_howexhaustbrakeworks.cfm
"Diesel engines control engine speed and power output by throttling the amount of fuel injected into the engine. A diesel has no air throttle.
Because it has no air throttle, a diesel engine offers virtually no engine braking when the driver lifts off the accelerator pedal. There just isn’t a
pumping loss to retard engine speed as the piston descends on the intake stroke. "
