Originally Posted By: Throt
Originally Posted By: JHZR2
Originally Posted By: Pop_Rivit
Originally Posted By: 285south
Block heaters are a must in COLD (below zero fahrenheit) climates like the midwest.
Complete, total and utter nonsense. Cars around here start just fine in sub-zero temperatures without block heaters. Even my 68 year old tractor started in sub-zero temperatures without a block heater-and it uses 15W-40 oil.
May be a smarter approach to getting some quick heat in subzero temperatures, as compared to idling a vehicle in the driveway/garage for a half hour.
Why folks cant add a layer of clothes and be a little tough is beyond me, but you know how many fight for their desire to burn a gallon of gas to warn the car up...
Couldn't agree more about leaving a car run for half an hour in the drive. My grandma gave me a car starter for Christmas and I returned it because I think they are stupid. I'd much rather have a block warmer than a car starter.
I'm not interested in getting a block warmer for my personal comfort of a warm car, it's an attempt to reduce cold start engine wear. Granted running Amsoil with a pour point of -63F helps a lot, a block heater would be the cats meow. For the low cost I think I'm going to go ahead and get one and as soon as the weather here isn't in the negatives, get it up on ramps and glued on.
I've decided on Wolverine (
http://www.wolverineheater.com) as opposed to Kats.
Or find a friend with a heated garage for installation!
Perhaps one could do the install after the car is nice and hot and even use a dryer if more warmth is necessary to warm the pan.
I looked on the web site but could not find the recommended temperature necessary for the glue to stick good to the pan.
I'll just say that when I first moved to the midwest(from south texas!) about 25 years, this midwest cold was something I could not tolerate and I installed a mag mount oil heater as well as a coolant heater on my truck and that was really nice. But as the years went by and I acclimated, i did away with those devices and focused on using the right fluids and keeping up with the maintenance of vehicle. This includes oil, transmission fluid, brake fluid, and power steering fluid as wells as belts. The battery is critical and load testing this before the severe winter hits is a very good idea. Just some food for thought and your post has also given me some food for thought as i get older and contemplate using one of these again! LOL
good day
