Block heater problems? Galvanic corrosion?
WA
Got my block heater in the mail today. Freeze plug variety. I noticed the heating element is copper... Or copper looking. Well being a Subaru, everything else in my motor is aluminum. Don't aluminum and copper tend to react negatively with each other? Galvanic corrosion?
The corrosion inhibitors should be able to cope with such a small amount of copper. Plenty of people use block heaters and i don't hear any big problems with them. This could effect your coolant interval though.
I know mixing copper and aluminum in a water cooled pc system usually ends up pretty bad, but car systems are probably different.
Well I ended up installing it. Did a 70/30 coolant ratio when I filled it. Hoping the extra anti corrosion agents will do their thing. I guess only time will tell.
