Blend and Full Synth
Yes! But I'd fill with 4qts; run the motor; let it sit 10 minutes; check to see if you need those 6 0z. As long as you are in the 'zone' between full and addaquart you really wouldn't need to fuss with it.
You guys might yell at me but one time I had a mix of about 4 different brands and weights,(partials)I wanted to use them all up,so I did,all in one change.It probably ended up with a 7w32 or something like that, I never noticed a difference in anything.
Is the extra 6 oz. really necessary? Chances are 4 quarts should put it very close to the full mark if not exactly on it. My car calls for 4 quarts and putting in 4 quarts puts it a little bit over the full mark. Most cars I've maintained are that way.
