I bled the brakes on the GP tonight and all went well...until I tried to close the last (front driver's side) bleeder screw. It was stuck open, I ended up stripping the head while trying to close it (rookie mistake of using a 12 point box wrench), and I could not get it closed with pliers or channel locks. I ended up pounding a socket on and twisted the thing off. It was pretty corroded and probably should have been replaced anyway. The replacement went on easily (I picked up an offset brake bleeder wrench while at O'Reilly's) and I re-bled that corner until there were no air bubbles. Is re-bleeding that caliper alone adequate or do I need to re-bleed all four corners to be safe?
