So, I had my used oil analysis done (https://bobistheoilguy.com/forums/threads/chevron-supreme-sm-gf-4-10w30-5-300mi-1999-civic.154165/) and I was curious about my 0.5% insolubles count.. Here is the email communication::
Would it be possible to reduce the insolubles value by switching to a
better oil filter? I was using the Purolator Pureone pl14459 oil filter
for this analysis. I don't know what filters are better than this one.
Do you think the insolubles level is causing any wear? At what value of
insoluble % does wear start to occur (generally speaking)?
Thanks
Theoretically, switching to a better oil filter would reduce insolubles.
However, we don't normally see much difference between the various oil
filters that are on the market, so I couldn't tell you which one to try. If
you wanted to switch to another brand, it certainly won't hurt anything.
Fortunately, your level of insolubles isn't really a problem. We don't get
too concerned about them unless we see 0.6% and higher. Beyond that, it's
possilbe to get into an oil starvation issue where the filter is too
clogged to work. That's when we'd see the excess wear. Hope that answers
your question. Let me know if you have any others and have a great weekend.
Blackstone Labs
Wow your saying that there is no real-life differences in the amount of insolubles not filtered out of the oil by the various brands of oil filters? The cheapest FRAM is just as good as a Purolator Pureone or an Amzoil eao ( http://www.amsoil.com/storefront/eao.aspx) ? My filter for instance is rated to filter 50% of particles down to 5 microns, I don't know if that is first pass, or on average after infinite passes or whatever or if absolute or relative but it makes me think that the filter should catch anything that your oil analysis would pick up in the insolubles count.. The cheapest FRAM filters are like 95% at 25 microns I think, and can't touch 5 microns particles.
Maybe my level of 0.5% is because the filter was full and was bypassing
Yea I won't worry about 0.5%, I'll stay below 5000OCI.
Either the Fram or the more expensive filters should work just fine. We don't see a whole lot of difference between them. See you in another 5,000 miles.
Blackstone Labs
Interesting, eh?
Thanks
Blackstone Labs
Blackstone Labs
Interesting, eh?
