15 years ago, I remember more than one person active in steam preserveration/operation claim that a Big Boy would never again be under steam. I'm glad that they were wrong(those same people also said the same about N&W 611, but here we are...).
I've unfortunately not seen one under steam, but we are fortunate here in St. Louis to have 4006. Although this one probably truly will never be under steam again, it's still impressive to see especially to be able to literally see side-by-side how massive it is compared to a lot of other steam locos.
At least this one too you can climb into the cab and see what's going on. By the way, I've been in a few steam loco cabs...and well a half dozen people could probably stand comfortably, and few others on the footplate.
With all of that said, though, I admit some partiality to Eastern Mountain steam, and N&W in particular. Consequently, it's an even bigger treat to see this a few hundred feet away. This is a Y6a-it's a bit smaller than the Big Boy, but as a simple articulated would beat the Big Boy in tractive effort by a decent margin. The Big Boy does offer more drawbar pull-one of those things why there's so many things that go into the debates about whether the Big Boy, Y-Class, Allegheny, or one of a few others are most deserving of the "biggest"steam locomotive label. Both the Big Boy and the Y had similar design goals-hauling big heavy freight trains over the mountains at moderate speeds(50-60mph).
I don't have exact fuel consumption figures at hand, but as a Mallet I'd expect the Y class to be somewhat more efficient than the Big Boy For those not versed in steam terminology, notice that the Y6a front cylinders are considerably larger than the rear cylinders. Steam locomotives were designed as either "simple" or "compound". A "simple" engine feeds all cylinders with boiler pressure steam(2 cylinders in most non-articulated/duplex locomotive, 4 cylinders in an articulated). A "compound" locomotive has additional cylinders(sometimes down in the frame on a non-articulated design, like the British Gresley Pacifics that had a 3rd cylinder in the center) that are fed exhaust steam from high pressure cylinders, extracting more of the availabe energy of the steam. A "Mallet" is an articulated locomotive where the front cylinders are low pressure(most Mallets can operate in "simple" mode, feeding boiler pressure to all cylinders, to start, and then can be switched when underway).
In any case, I wish we'd see this one under steam, as it is the only surviving member of the Y6 class. It's a shame N&W didn't preserve any examples of the even more advanced Y6b
Combustion should be occurring in both the firebox and the boiler flues. In fact, in a boiler of this size, I can’t imagine the stress that only having combustion in the firebox would cause.
In fact, oil conversions of coal locomotives are not always successful for that reason. A coal firebox is designed so that a lot of the coal in the firebed is actually "coking out", and the gases that are released in the coking process are drawn into the flues and burn there, although they also depend on having that stability of the big hot firebed throwing out a lot of heat. Oil burners need to atomize the fuel enough-often with an elaborate steam jet-that it can be drawn into the flues and then combust there.
The smokebox has to be pretty darn heat tolerant considering that it's inevetable that some combustion will happen there too-that wouldn't be as desireable since it would mostly be wasted, but it will happen. I seem to remember too that with coal, there's a certain balancing act(really an art) to having the firebed be the appropriate depth, as too deep is sluggist to respond and difficult to draft through, but too shallow can be lifted off the grates under heavy drafts.
BTW, I seem to recall some discussion from folks who would know that that the Big Boy oil conversions were not particularly successful and that they didn't steam particularly well after the conversion. I do seem to recall that a lot of work was done on the firebox during restoration to better adapt it to oil burning...
