What is the lube you use?I hold a rag in the curled palm of my hand and run the chain through, applying very little pressure to both sides of the chain. The cloth picks up some dirt. I'm certainly not working dirt into the rollers. The lube I use is not a wet lube. It leaves a resinous coating that isn't sticky. I ride in mostly sandy and dusty conditions. I don't think sand sticks to the chain. My friend uses a wet lube and his chain picks up hair from the dogs on the trail, sand, and pollen.
