Originally Posted By: Magpie10344
I was told recently that when BG quick clean is ran through the engine that it is imperitive that MOA is ran with the new oil. Does this hold any truth to it?
Yea..I heard the same speal from a mechanic long-distance. But he was hyping BG big time. I'd used 44K before and had excellent results. I used BG109 engine flush after replacing my PCV system to remove as much black, gas-smelling oil as possible. Then I refilled with synthetic & added the MOA. Didn't hurt, but then again why pay for it when you're already using 100%syn oil?
I think it's an older product meant for use with dino (conventional) oil, not synthetic.
As to accuracy from local distributers, I called and was told that you could add 109 and drive around, no problems. It would soon evaporate. I replied the can doesn't say that. Further, it kills the viscosity...flies out of the drain hole like water. I ignored his advice and followed the directions on the can.
