- Joined
- Jan 1, 2024
- Messages
- 39
I just found this product. Any Good ??
Based on what?
Why?Good stuff but change your oil after using it.
According to this gentlemen that tested these cleaners for PEA content, BG44K has one of the highest. Any of the PEA content products will get the job done according to anecdote evidence at BITOG.Based on what?
The only thing missing here is some acetone... smh.
Even in its current form you could probably use this stuff as paint remover.
@USA get yourself some Red Line Si-1, Chevron Techron, or AMSOIL Fuel System Cleaner, and don't worry about the BG 44K.
At most, the SDS accounts for 77.5% of what's in the can. At the least, it's 26.6%Based on what?
It cleans out a lot of junk that could contaminate your oil. Most mechanics will tell you this because they have been trained by their BG rep.Why?
I am a tech at a shop, but the BG rep never mentioned this.It cleans out a lot of junk that could contaminate your oil. Most mechanics will tell you this because they have been trained by their BG rep.
EPR is the oil change one. 44k and MOA get added at the oil changeI am a tech at a shop, but the BG rep never mentioned this.
Never thought I'd see the dayIt's so good it's even now a GM product. Part number 19435370 and the cases that its packaged in comes with the gm Genuine Parts hologram sticker.
What is the price comparison?Never thought I'd see the day
Yes I know that. He said you needed to change your oil after using 44k.EPR is the oil change one. 44k and MOA get added at the oil change
our dealers price almost doubled when it went to ACDelcoNever thought I'd see the day
Made a difference in my DD Corolla after years of Techron use. Car had more power (back to original?) but when driven normal, documented increase in MPG. Working off hours with little traffic makes that easy to check when each tank is filled up all the way (topped off) and written in log book.44K + MOA + Italian Tune Up = Placebo for Cheap Customer that really needs top end work.
I'm glad it worked for your Corolla!Made a difference in my DD Corolla after years of Techron use. Car had more power (back to original?) but when driven normal, documented increase in MPG. Working off hours with little traffic makes that easy to check when each tank is filled up all the way (topped off) and written in log book.
Not placebo with same results in other vehicles. Never needed top end work. 40+mpg on highway trips with over 200k on vehicle.
Mileage went down after swapping transmission fluid to BG Synchroshift II. That eliminated light grinding between gears especially at higher rpm's. That made it fun again to be close to redline which kills mpg.![]()
