I personally don't worry too much about cat poisoning. I only caution people to be aware of current additive policy and why it may be something to consider. I use HDEOs and don't think twice about it ...but I'd be negligent in blindly telling someone else to take the risk, however small, that I have accepted. It was the same with my MMO massive dosage trial. I specifically stated that I didn't recommend it and only did it to prove what didn't happen in my usage.
I mean we're all intelligent people here ..but without completely qualifying what you say ..you can give the wrong impression. We all, with the wisdom that is gained with age, learn to CYA. Even on an anonomous internet message board.
The advantage that I have with the use of HDEO synth is that I use them over a relatively LONG duration compared to most of the membership here. Hence any volatilization from that oil will be very low on a per mile/year basis if any adverse effects are indeed associated with it. I get my money's worth out of these oils. If I couldn't go so long, with confidence, I would not use them.
You're in a severe climate ..at least for the winter. You've got certain issues to deal with that I do not. I would think that even with that qualification, the XD-3 synth line would serve you well on a 6 month basis ..or perhaps broken up biannually with a shorter bias to the winter (6/6 - 5/7 - 4/8 type thing) depending on what your daily drive is like
Again, I think that the additive issues are a "time weighted average" type thing. My wife does 18k a year. I've been using HDEO for the past 60-70k (I forget the exact mileage) ..but that only represented 5 or 6 OCIs and took 4+/- years to accumulate (of HDEO use). This could actually have been LESS cat poisoning then someone in another type of service would encounter with 15-20 OCIs with PCMO (if you see how I'm viewing it here). So you could say that my risk is well managed ...or at least "rationalized"
Just another tidbit to add a moment or two of reflection
"Surprises around every corner, but nothing dangerous" - Willie Wonka
