Recently changed manual transmission fluid (GL-4 gear oil) & diff fluid (GL-5 gear oil) in two separate vehicles.
For the transmission fluid, the fill plug was fairly high on the transmission, and there was no way to get a funnel in there. I have a cheap little plastic hand pump that isn't ideal, but didn't see any other way. It did the job.
For the van, there was enough room above the pumpkin that I was able to bend a long-necked plastic funnel enough to get it in place with the opening sticking more up than down. Had room to pour from the AMSOIL 1 qt bottles into the funnel.
I would like to buy a better pump - the plastic one's inlet & discharge hoses are just pressed into grommets on the body, and tend to pop off at inopportune times.
The other, low-budget solution might be to buy hose of the right diameter, and be able to pour into a funnel from above.
Who has used what, and what's worked best?
Thanks!
Thanks!
