If you're looking for the 'best of the best' you'll need to compare oil test results in similar applications over extended periods, ideally with your specific vehicle. If you're looking for something that will work fine there's a variety of products available. I use Mobil 1 75W-90 in both axles of my truck as although it's a bit expensive it's still about half the price of the dealer oil, and hasn't seemed to generate too many complaints about wear, cold or hot weather operation, and use in longer drain intervals. Amsoil seems to have similar attributes. Redline seems like it has some problem here and there, and based on some comments is possibly not the best choice for extended drain intervals.
