my dodge dakota 2008 has a 3.7l v6. - owner's manual calls for .043 spark plug gap. I bought autolite xp 5224, with iridium centre and platinum ground.
I gapped them for .040 because with wear the gap will gradually get bigger and reach .043 naturally. I read the following internet picture:
http://us.st12.yimg.com/us.st.yimg.com/I/machv_2040_157904138 which shows that
an iridium plug will ignite a leaner mixture than regular or platinum plugs, and has a nicer flame kernel, so probably the minimally smaller gap that I set on this iridium/platinum plug is ?good, or ?bad.
Also, I notice the 4.7 v8 engine in the Dakota has a gap of .040, so does that mean that .040 should work well with the 3.7 v6?. I am being extremely careful to make sure the plugs are gapped EXACTLY the same, because I read a long time ago, that the precise gap is NOT as important and the UNIFORMITY of the gap, because a slightly tighter gap will fire quicker than a larger gap, the engine will not run as smooth if the gaps are different among the plugs, and possibly you could even get knocking in one cylinder with the tighter gap and not another. Also I read to put a bit of anti-seize on the threads, and use a torque wrench!
the plugs are difficult to change, so i just want to do this once, and then not worry for 100,000 miles. Can I trust my local mechanic to do this job? or should I ask the stealership?
