Best product to remove dog scratch on paint.
The Woods of NY
I’m looking for a product that maybe I can use to compound or buff out these superficial light scratches on black paint. It looks like a dog jumped up on the paint or something.
I’m not looking to do a full paint correction or anything like that I don’t think lol Suggestions? The spot is not terribly big maybe the size of the gas cap cover total. I did put wax over the spots for now and they got a lot better so that gives me hope I can buy a product specially made for these type of scratches and have great results.
Thanks 🙏
It's hard to judge without seeing it in person.
I'd probably wet sand them.
I don't know what you have on hand but I'd try maroon bottle Meguiars Rubbing Compound first.
I think those scratches might have been caused by something.
If you can feel them with your fingernail then only a correction will remove them.
For something quick and easy, wet sand with 1500, then 2000. Follow up with polishing compound like Meguiars 110, twice, using a dual action polisher if you have one, by hand if you don't. Finish with wax or sealant of choice.
I would start with a 3000 grit finishing paper or foam pad. You can always go heavier on the abrasive if needed. Then move up to a red compound of some type, followed by a white, and then a finishing glaze. Finally you can wax it with a good cleaner wax that contains a mild abrasive to get the polish shine you are looking for.
I wouldn't go grabbing sandpaper and grinders before I tried some rubbing compound as it works a lot better than one might expect. Rub it aggressively and see what happens.
