Hi guys, I have Mercedes W210 E 270 (125 kW) with OM 612.961 engine produced in 2000 year with no DPF filter. In last two years I've decided to change oil in my garage and started to questioning about recommended oil for my car. In owner's manual said that should use oils with 229.1 or 229.3 MB approval. Since oil industry developed tons of new oils and new MB approvals arrived I had no idea is there better oil than those with approval 229.3 for my engine. After calling at least 10 Mercedes authorised services I've ended with next approvals suitable for my engine 229.3, 229.31, 229.5, 229.51 and 229.52 approval. While searching on internet I've found this document where my engine is in Van row but that is ok because this engine is used in Mercedes Van cars and it confirms that mentioned approvals (229.3, 229.31, 229.5, 229.51 and 229.52) are suitable for my engine.
As my car doesn't have DPF filter is it better to use 229.x oils since 229.x1 are Low SAPS oils for cars with DPF filter and if so is better to use 229.5 approved oils?
Also in description of 229.52 approval said that it can be used for cars with or without DPF filters but does that advantage to be used in both decreases oil performance in comparison with 229.x oils?
