My truck has somewhere north of 310k on it, possibly as high as 410k, i was running castrol 10w-30, but it wasn't keeping the oil pressure up or keeping the lifters pumped up, so i switched to RP 15w-40 and that kept the lifters happy and it kept my mpg up, but it wasn't helping my sludge problem, and the stuff is about as expensive as liquid gold.
so yesterday, i bought a gallon of Rotella T6, 5-40 and filled it up, but i screwed up putting the filter on (forgot to pull the old o-ring off the socket and dumped all the oil out, last time i forgot the drain plug)
and i couldn't afford another fill of T6 so i had to go with the Regular Rotella T dino oil.
It's kept the lifters pumped up so far, and i haven't really driven it enough to know what effect it's going to have on the milage, but for the first time in a while the oil pressure is within spec, 15-18 pounds at warm idle, 50 at highway speeds.
Should i still with the Dino rotella, go back to the T6 next time i change, or is there some other oil that would be best?
Engine is a 2.9 V6, i drive it 70mph or higher on a regular basis, and i do some light offroading.
