Originally Posted By: jk_636
Why would you run an oil filter for two OCIs? That is nonsense. Oil filters are cheap. Take it off, throw it away, swap it out and go back to better filtration. I dont buy into that bunk that the older a filter gets the "better" it filters.
Nothing wrong with running a filter for 2 OCIs assuming its rated for the anticipated use. Be sure your engine isn't sludge'd either.
If you don't run them at least close to their full potential, you might as well buy something a bit cheaper. Motorcraft for example. The FL400s will work for your truck.
