Originally Posted by Dogred08
I figured the extreme carbon build up would cause the compression to increase causing spark knock that's why I cleaned it was to reduce compression
That's true but you are also cleaning the valves and seats and replacing an old head gasket which likely may not have been at 100 percent either.
