- Joined
- Aug 9, 2022
- Messages
- 155
Hello All,
I wanted to share a piston soak procedure from Hyundai service bulletin 21-EM-003H that I found interesting. After adding 2 ounces of cleaning solution into the cylinder, they have you pressurize it to 30 psi for 3 minutes using a leakdown test tool to force the cleaning solution into all of the piston ring lands. To further agitate the cleaning solution you then connect a hose between specific cylinders and crank the engine 3 times for 3 seconds. Note that they say this can be done every 36,000 miles as part of routine maintenance. While I probably wouldn't do the agitation step, I think adding a pressurization step to a standard piston soak would make it much more effective. I am interested to hear everyone's thoughts, especially anyone that has tried something similar on their vehicle.
