Best High Mileage Oil
Tennessee
It was confirmed that I had a small rear main seal leak on a 2008 Dodge Grand Caravan with 67k 3.3L. I've always ran Castrol 5w20 and started noticing consumption around 2 oil changes ago. It leaks around 1/4-1/2 quart in 3000 miles. I am just trying to slow the consumption. I took the van to the Dodge Dealership and they were not able to find a leak. I'd like opinions and comments on the best high mileage oil that could help out with a POSSBILE rear main seal leak. Any recommendations? I
Valvoline Maxlife is highly regarded here. If I needed to use a High Mileage oil I would go with Valvoline or Pennzoil High Mileage oil. Any reason your leaning towards the Castrol High Mileage oil?
I had a 4 cyl caravan that would leak a small amount sometimes from the rear main area and regular pennzoil 5w30 made it go away.
This is anecdotal of course, but I would use it again if I had the same problem.
I have used all the above oils and am currently impressed with Pennzoil High Mileage conventional. It has slowed/stopped leaks in my sons car and none of the others seemed to do anything.
I have used Mobil 1 High Mileage in many cars and I do not believe that it will stop or slow a current leak. I think it may help prevent a leak but I have never seen it stop or slow one.
Maxlife remains the king of High Mileage oils. There are some very strong contenders available these days though. We kinda have two tiers of High Mileage oils these days as well, "thick" for grade and "typical" for grade.
"Thick" for grade: Defy, Pennzoil High Mileage, Castrol High Mileage, Mobil 1 High Mileage.
"Typical" for grade: Maxlife, Mobil Super and I think I am forgetting somebody.
I tend to like the thicker ones myself but I'm a Jeep guy. Have used Maxlife a ton in our other cars, great stuff.
My personal opinion:
1) Maxlife
2) Pennzoil High Mileage
3) Tie Castrol and Defy
Depends on the application though I'd not run Maxlife in my Jeep but it would be my top pick for another vehicle.
Originally Posted By: 901Memphis
Move up to Maxlife 5w30 and add a can of liqui moly motor oil saver too.
+1
ATP AT-205 Reseal also works very well in stopping leaks. Adding it to MaxLife yields surprising results.
Give Defy a try. Just a great all around oil. I'd use 10w30 or 10W-40 in your application. Of course Defy is available in 5W-20 and 5w30 too, so pick whatever grade you like.
Every store I've visited, the only Defy I see is 5w30 and 10w30. I'd love to find it in 10w-40.
I know one thing about High Mileage oils: the ONLY 20w-50 product I've ever seen is Napa's brand. I know Valvoline makes it in Maxlife, but I've never seen it anywhere.
Never seen Castrol GTX 20w50?
Every high mileage oil listed in this thread will work well for you. Get whatever is cheapest.
At only 1/4 to 1/2 a quart per 3000 miles, moving up in weight isn't necessary IMO. Wont hurt, but isn't necessary.
Only the regular white bottle.
Lol sorry I didn't read at right, didn't see High Mileage at first
+1
My dad had a RMS leak on his 06 LTC. He used Valvoline MaxLife and Lubra-Moly and the leak was stopped after about 4.5K miles.
