Quote:
I drain the radiator, add in a flush and refill with tap water, run the engine for 15-20 minutes (that should allow enough time for it to circulate at operating temperature) with the heater on high. Drain the radiator, remove the top hose, refill the radiator with distilled water, run the engine with the heater on high, and continue adding distiled water until clear water comes out of the water outlet. Then drain the radiator, add in enough coolant to give a 50/50 mixture. After that I let it sit with the radiator cap off overnight, top off, drive and top off as necessary, continue that until no more coolant loss occurs.
