Originally Posted By: Test_Drive
Slightly OT:
Long ago, I thought about switching to Motul DOT 5.1 brake fluid. It was not because I needed the high boiling points, but because DOT 3 had a low temp viscosity limit of 1300cP, whereas DOT 5.1 was 820cP.
It became an issue during a -35*C cold snap, where the clutch was VERY sluggish due to the viscosity of the brake fluid. And of course, ABS was disabled for the first few minutes of driving during that week.
....never got around to changing it out though.
Can anybody comment on whether the difference in 820 vs 1300cP would have quelled my irritation with the molasses in the clutch?
I believe it will help.
I guess the reason why they put DOT 5.1 standard is because they want lighter viscosity for ABS working properly and high boiling point like DOT 4.
The brake fluid manufacturer normally do not advise people changing from DOT 3 to DOT 4 fluid if the system has ABS. However they recommend DOT 5.1 for compatibility with DOT 3 and DOT 4.
Slightly OT:
