W wjli Joined Mar 2, 2009 Messages 152 Location georgia Sep 3, 2009 #1 which conventional oil do you feel has the superior add pack? what about the highest TBN as well as best TBN retention given set circumstances? thanks.
StevieC Joined Aug 21, 2008 Messages 25,104 Location ON, Canada eh? Sep 3, 2009 #2 What is the application?
JHZR2 Staff member Joined Dec 14, 2002 Messages 56,209 Location New Jersey Sep 3, 2009 #3 That ties at least to some extent to the metalurgy. The best add pack is relative to certain metrics. The one with the best TBN retention may not be the best one that has the highest EP, AW, FM, etc.
A addyguy Joined Sep 8, 2005 Messages 16,597 Location Canada Sep 3, 2009 #4 Formula Shell Conventional, looks something like: Moly - 40-60ppm Boron - 100-150ppm Calcium - 1900-2100ppm all others at 'SM' levels.
L lexus114 Joined May 12, 2008 Messages 6,318 Location Canton, GA Sep 3, 2009 #5 Originally Posted By: addyguy Formula Shell Conventional, looks something like: Moly - 40-60ppm Boron - 100-150ppm Calcium - 1900-2100ppm all others at 'SM' levels. I`ve used that oil just recently,and it seems to hold up very well.
StevieC Joined Aug 21, 2008 Messages 25,104 Location ON, Canada eh? Sep 3, 2009 #6 F.S. oil is very good oil...
Z ZZman Joined Mar 17, 2008 Messages 8,779 Location Michigan Sep 3, 2009 #7 Pennzoil conventional. Check the used oil analysis section.
E element_42 Joined Aug 7, 2008 Messages 152 Location Pickering Sep 3, 2009 #9 a conventional with the strongest add pack would most likely be an HDEO
bigjohn Joined Jun 22, 2008 Messages 1,520 Location Colorado Sep 3, 2009 #10 Originally Posted By: element_42 a conventional with the strongest add pack would most likely be an HDEO yep.....Delo
