Berryman's B-12 Chemtool any good?
i did the sea foam thing (ran it down a vacuum hose) with b12 today. no smoke but it missed for about 10 mins afterward. runs about the same, butnit wasnt running bad to begin with
It didn't smoke for a reason.
Some think it he smoke means it's cleaning, nope!
It smokes because seafoam has oil in it. You are burning oil from the product. I personally have no use for seafoam.
I use b12 for a tank, then techron for a tank prior to an oil change.
after seeing this i think seafoam has a use
Chemtool is excellent and one of two products I use, the other is a high PEA cleaner like Redline SI-1, Techron, Gumout AIO.
There are two types of fuel system and injector contaminates that can be helped with these products and some that nothing will help. The ones you cannot do anything with are sand or similar that got into the system (more common on small marine stuff) and incinerated nylon fuel filters in the injectors (DI injectors).
The two you can do something about are varnish and hard carbon deposits, varnish is common in all engines including carbs and especially small engine OPE, this is where Chemtool really shines,it will remove varnish deposits almost on contact. Using a splash of Chemtool in OPE tanks a few times a year and before storage will prevent carb issues almost indefinitely.
My Lawnmower and snowblower are both 14 years old and still have the original carbs and have never been cleaned or adjusted, both start first pull and run perfectly. The Chemtool really works well but it does not do as well on hard carbon heat formed deposits commonly seen on the business end of the injectors. For this type of deposit PEA based cleaners do the best job.
The PEA cleaners are not great on varnish, their effectiveness is minimal compared to Chemtool, from my experience the most effective to maintain the whole system cleanliness is to use both types of cleaner alternating them for a few tanks. OPE and other engines with carbs are not subjected to the kind of high temp deposits found in injected engines so Chemtool is all that is required.
Good information ! 😎👍
Redline si1 is proven to clean. I'm convinced that b12 makes a noticeable difference because the solvents are high octane so less timing is pulled. For this reason, buying btx compounds in bulk and dosing your fuel can work out cheaper than buying super unleaded.
Anecdotally, oil in your fuel improves ring seal and has a knock on effect on mpg despite lower octane and potential pulled timing.
Occasionally, when the mood takes me I'll fill a 5 gallon Jerry can can with equal parts SI1, acetone, toluene, tcw3 and leaded race fuel, adding maybe 200-300ml per full tank of fuel. It might just be placebo but it feels good knowing (assuming) I'm improving commercially available petrol.
Without this alchemy, cars still run perfectly well for many hundreds of thousands of miles so in the end it probably doesn't make any difference.
What would be the effects of adding methanol to a tank of gas?
Say 15/1 gas/methanol. I can get methanol for $5.00 a gallon.
I was going to get some to mix shellac flakes with.
I went to Walmart to get some Gumout Tune Up and couldn't find any so I bought Berryman's for the first time to try it.
What are your thoughts on it?
The same, better or worse than something like Regane or Techron?
Berrymans is excellent at removing carbon & varnish. Works on my small yard engines & cars. But it is not formulated the dissolve ethanol deposits****
Say 15/1 gas/methanol. I can get methanol for $5.00 a gallon.If Gas
Some gas line antifreeze like Heet brand are methanol to mix with water and disperse it in the fuel so it doesn't pool and freeze in the lines. Some use Isopropyl. Part of why that isn't much of a problem anymore with E10 just about ubiquitous.
