This is a new Bentley GTC used oil analysis at 1, 2 and 3,000 miles taken from the OEM oil. The first factory scheduled oil change is at 10,000 miles. My plan is to run a used oil analysis every 1,000 miles for as long as I can stand not changing the oil or to 6,000 miles, whichever occurs first. No oil was added.
The engine is a 6.0 liter twin turbo W-12 with 550 BHP, compression ratio 9:1, top speed - 198 MPH and 0 - 60 dash = 4.8 seconds. The curb wt. is 5,500 lbs., EPA 11, 24 MPG,
......................1,000 mi.....2,000.....3,000.....4,000.....5,000.....6,000
Iron__________22________23____33
Chromium _____ Nickel _________1________2_____2
Aluminum _____5 ________7_____6
lead __________ 1________1_____3
Copper ________32_______34____41
Tin ____________5_______3______3
Silver ________ Titanium _______ Silicon ________ 37_______34____39
Boron _________228______195____219
Sodium _______ 15_______12_____13
Potassium _____ Molybdenum ____91______81______92
Phosphorus ___1027______936____1035
Zinc ________ 1151______1027___1182
Calcium _____ 3228______2915___3301
Barium _______ Magnesium ____22________21_____29
Antimony _____ Vanadium _____ Fuel %Vol _____1.5______ Wtr %vol ______ Vis CS 100C __ 12.3______12.1____12.1
SAE Grade ____30________30_____30
Gly test ______Neg_______Neg____Neg
TBN ________not done____NA_____NA
Obs Oxid______23_______27______29
Abs Nitr_______10______13_______14
Fuel soot______NA______NA______0.0
Test lab was: youroil.net
aehaas
aehaas
