bent pulley on Ariens snowblower
Near the beach in Delaware
The 8" pulley that drives the auger on my Ariens 36" snow blower was bent when I split the machine apart to change the belt. I cannot see how that could happen as one really does not have access to the pulley unless you split the machine apart.
Seems very odd unless someone used a crowbar against the drive and auger pulleys to split the machine.
That would be my guess as to how it happened, unless possibly something solid got behind/under the belt guard and jammed in there at some point.
Originally Posted By: old1
Maybe somebody tried to change the belt without splitting the machine
Unless they used a crowbar to force the belts, you cannot easily bend the pulley.
+1 to that. The auger belt could have jumped at one point and a previous owner attempted a belly-pan belt replacement, and got overly aggressive trying to dig out the old belt, etc..
FWIW, when ever possible, I do belt replacements by belly pan removal alone, but I've done a few and don't attempt them demolition-derby style.
