One of the reasons why I have gotten excellent results with extended drains is that I use the Amsoil PI gas additive on a regular basis. I carry a bottle in each vehicle and add 1 ounce for every 10 gallons of fuel. This helps keep combustion efficiency high and reduces the impact of fuel contamination on oil oxidation and thickening. These are the seven most recent extended drain, oil analysis results I've gotten with regular use of Amsoil Performance Improver, using a variety of Amsoil engine oils.
Oil type/ miles on sample/EOT viscosity
0w-30/12,000 miles/11.2 Cst
10w-30/12,000 miles/11.2 Cst
20w-50/12,000 miles/19.8 Cst
0w-30/16,000 miles/12.7 Cst
Series 3000/15,000 miles/12.1 Cst
Series 3000/21,000 miles/13.0 Cst
5w30/12,000 miles/10.9 Cst
If you are seeing high levels of oxidation/nitration or total solids in your used oil samples, I highly recommend regular use of this product. It will improve the solvency of the fuel you use and the crankcase oil will hold up better.
Tooslick
Tooslick
