Hello BITOGers,
I've noticed recently that the engine belts on my '09 Pontiac G8GT have been making an annoying chirping sound. Basically when I drive it sounds like I have an active bird's nest under the hood. The car only has about 18,500 miles on it so I'd be a bit surprised if the idler/tensioner pulley on the serpentine belt or the belt itself is worn out.
I figured perhaps the belt/pulleys built up some dirt so I sprayed some Simple Green on the belts/pulleys and then hosed them off. When I ran the car after that, the chirping at idle stopped but was still present at any rpms basically above idle. So, I tried it again this morning. While everything was still wet I started up the engine and everything was perfectly quiet. Idle, revving, both yielded no chirping noise so I thought I had it licked. I came out 20 minutes later to go to work and when I started up the engine, the chirping noise came back.
So, I’m not sure what else to try? I’m a bit baffled as to why the chirping stopped when the belts were wet but came back when everything dried off?
Any ideas?
Ed B.
Any ideas?
Ed B.
