One of my cars ('66 Dodge Polara, 440 powered) HATES winter blend fuel.
Specifically, it vapor locks because of the high vapor pressure/lower boiling point used in winter blend gas. I frankly don't see the point of winter blend gas in a climate where we can get lots of 70+ degree days all thru winter, and rarely get below 20F *ever*, but I digress.
What's been done:
Electric fuel pumps (yes, two- a lift and a pressure pump)
insulated fuel line
Re-routed fuel line away from heat as much as possible
insulating spacer under carb
intake manifold heat passage blocked
That still doesn't cut it on some days and I get vapor lock. VERY annoying, and its definitely winter fuel- it will run right thru summer with 110+ degree days and never miss a lick, but come an 80-degree day between November and April with winter fuel... tthhhpppt!
Are there any fuel additives that can reduce the tendency to vapor lock? I'm guessing not, because I'm guessing that the gasoline is actually blended from lighter fractions and there's no way to change that characteristic... but I thought I'd ask.
I may have to resort to putting a fuel return line on it to use the tank as a heat sink and keep colder fuel always available right at the carb inlet (ala '60s Mopar muscle cars with 440s and Hemis straight from the factory- my '69 Coronet with that setup has *zero* problems).
Any other suggestions? I do have an extra Thermoquad carb I could try, but sheesh- I really don't want to do that with all the detail work it would take to get a TQ tuned and reliable with modern (alcoholic) fuel. I like my dead-nuts-simple all metal Thunder Series AVS.
What's been done:
insulated fuel line
