Bearing-like noise between CV Axle and tranny?
Ohio, USA
While I was changing my oil, I've noticed a leak coming between the tranny and cv axle. Now the car is making a bearing-like noise. Besides tranny oil, is there any other gasket around that area? What's making the bearing noise in that area? I recently had my CV axle, ball joints, wheel bearings replaced. T
Probably a failed seal where the CV joint spline enters the final drive. Have you checked to make sure there is enough fluid in the final drive/transmission?
Check the level first.
Maybe bringing it back to the people who worked on it is still anoption.
They replaced parts, now it leaks and makes noise.
