I have a Digital Harbor Freight Battery tester that gives resistance reading based on the CCA value you put in based on your battery. Does the Temperature at the time of the test affect the estimated CCA that the battery has at the time? What ambient temp do I use to test? I have seen the voltage table vs temp to rough guess a state of charge. I know there are more accurate testing equipment out there. Thanks
