Trying to determine if I have a bad battery or alternator, 2009 Jetta 2.5 167k. First attempt to start it this morning, clicks like a bad battery and no start, the battery was at 10.1 volts. It started with a jump pack so I drove to AutoZone and had them test the battery and alternator. Their test showed battery good and charging system bad.
A few hours later I tested the battery again. The battery was at 12.6 volts, dropped to 7.8 volts when cranking and 13.8 volts idling. Voltage drops to 13.6 volts with headlights and AC turned on.
Does this sound like a bad battery or bad alternator?
