I have a 2007 Chevy Impala with bumper to bumper warranty. I have had into the Chevy garage 3 times for a dead battery. I'll tell you about the problem and then what the garage has done to fix it. See if you can solve this mystery!
The battery goes dead if the car goes 4 days of so with out driving it. If I drive it everyday, no issues. When I go on vacation or a long weekend and let the car sit, the battery goes dead. So, I assume either:
1. Bad battery
2. Bad alternator
3. There's a drain on the battery.
The first time I took it to the Chevy dealership, they recharged the battery, tested the alternator and said everything is fine.
Still happens...
The second time I took it to the Chevy dealership, they said the battery was bad and installed a new battery.
Still happens...
Today, they had the car for 4 hours. The battery (new) tests fine, the alternator tests fine, and there is no parasitic draw on the battery. They are clueless! They do acknowledge the problem because they noticed the battery was almost dead after I just drove the car 45 minutes to get it to the shop.
I think the alternator is bad even though it tests fine. Is this possible? The dealership refuses to pay for a new alternator unless it actually shows up bad on the tests. I think it's the alternator because after driving the car 45 minutes to the dealership, the battery should be fully charged and it wasn't. It was almost dead. The battery certainly didn't lose over half its charge sitting in the parking lot for 5 minutes waiting for the mechanic.
Any ideas??
1. Bad battery
2. Bad alternator
Still happens...
Still happens...
Any ideas??
