I have windows XP.
my printer is a Canon (regular ink jet, using regular pin-type connector; this is the current printer installed on my PC)
I have another HP laserjet printer, which is a newer, USB plug & play type.
If I install this printer using the "add printer" wizard, would my Canon printer be automatically removed? (I don't want to)
I want to have my Canon printer always connected, but use the HP printer whenever I want, thru the front USB port...
How would I be able to select which printer I want to print on?
If I install the HP, and whenever I have it connected thru USB port, and I click print, will I get a prompt asking me to select which printer I want to use?
...how would this work?
Thanks a lot for any advice.
