Originally posted by Malaclypse:
" The 3800 (3.8 V6) will have more coolant leaks from the upper intake than the lower. This is because two different materials are being used. Aluminum for the lower intake and a plastic/composite upper intake. The difference in materials means that there is a difference in expansion rate between the two. Over time this caouses the Upper Intake gasket to wear because its sliding between two surfaces for each warm-up and cool-down cycle the engine has."
Is there any possible preventative maintenance that can be done? I am thinking about adding some Bar's Leak (black oily version) addative when I change the cooland out in order to shore up any worn gasket area.
