Interesting info contained in a link posted by Buster, on the main forum - one of the sources of base oils for bar & chain oil formulations is the rinse used to clean out lines of blending & packaging equipment.
Unlicensed Motor Oils - Lube Reports Article
The article is describing how some questionable quality, SA motor oils appear on the market:
quote:
James Taglia, president of Nor-Lakes Services Midwest in Hugo, Minn., and currently president of the Independent Lubricant Manufacturers Association, Alexandria, Va., also pointed to the problem of “line wash.”
“We buy several hundred gallons of line wash every year, which we use for bar-and-chain applications, a legitimate usage,” Taglia said. “However, we understand some marketers are simply relabeling line wash as engine oil, which is not an ethical usage. Consumer education will not address this issue; it has to be addressed at the manufacturer level.”
