bandaid additive for tired trans
Originally Posted By: bmwtechguy
If thicker will help, some have tried the Lucas automatic trans product with good results- about $9 a bottle to gamble. If your low reverse clutch is leaking enough to not engage when fluid is hot/thin, this might help. I'm not a fan of Lucas stuff, BTW, but I have known this product to work at times. It does sound like a leak in that circuit since all of your forward speeds are ok? Only other time that clutch is used in when you pull it down into manual low for engine braking. Let us know what happens.
I agree. It'll get you a few more thousand miles out of it. Worked a few times for me.
So the consensus is to put Lucas in it? A different kind of fluid wouldn't be better? I was planning on changing the fluid anyways and I've never been a fan of additives, I don't run them in my engine and not sure about in my transmission.
I rec. that you use Lube Gard/Lube Guard. Check to see whether you need the red or the black bottle. You should change the fluid and then add the bottle. Make sure you don't over fill.
I don't like motor additives either. But I have used the lucas transmission goo with pretty good success.
Just an update, I have not added any additives yet, and drove the car from Ontario Canada to Carlisle PA and back plus all my normal long distance driving and go figure, I haven't had another transmission problem since.
