Originally Posted By: bmwtechguy
If thicker will help, some have tried the Lucas automatic trans product with good results- about $9 a bottle to gamble. If your low reverse clutch is leaking enough to not engage when fluid is hot/thin, this might help. I'm not a fan of Lucas stuff, BTW, but I have known this product to work at times. It does sound like a leak in that circuit since all of your forward speeds are ok? Only other time that clutch is used in when you pull it down into manual low for engine braking. Let us know what happens.
I agree. It'll get you a few more thousand miles out of it. Worked a few times for me.
