I have been going round and round with my 6 year old desktop that has recently taken to just shutting off. No error messages at all.
Suspecting the power supply, I bought a new one with more power as I figured the original PS had seen better days as the computer stayed on most of the time. Plus, it had a slight burnt smell from the cooling fan and components on the internal board.
The new power supply worked fine until I turned the pc on this morning. It shut down after a minute or so then refused to do anything when front power switch is pressed. It did come on, however briefly once then nothing.
I reset BIOS by removing battery and then decided to try shorting the two prongs that the switch connects too.
Presto! On it came! So I shut it down, removed the connector for the power switch and my meter shows it making connection when pressed. But hook that switch up and it won't come on at all....nothing. Short those two prongs and on it comes.
So I guess I'm asking is that can a switch act like this....like show it making contact when disconnected? But not work when connected up?
Are these switches designed for a certain amp or ohm load when starting the computer?
This is just a momentary contact switch and I do measure some slight resistance when checking it out.
Any thoughts?
Any thoughts?
