Bad O2 sensor?
NH
Pulled the codes for a friends '11 Sonata. I looked up the codes and it seems like it's got a bad sensor, but maybe it's something else? I'm thinking of clearing codes and seeing what comes back. I'm not sure what to make of the too rich/high and low/lean codes though.
P0136: Post O2 low V
P0140: no post O2 activity
P2096: post catalyst trim too lean
P2271: post O2 stuck rich
P0138: post O2 too high
Pending P0136 and P0140
O2 has 100k miles? Change it. A new one will bounce between .2v and .9v . Sounds like yours are bouncing too slowly. Just a wild guess.
I do have an o-scope. But that jogs the gray cells, I recall Torq has a graphing function. I used that to determine I had a bad O2 sensor in my car (which oddly never tripped a code). Maybe next week I'll look into that--not sure how much help I want to offer, 7 years of road salt should mean it'll come out easy, right?
Yeah, over 100k on the clock, like 178k.
You need a new downstream oxygen sensor. Denso and NTK are the best ones to get
Most likely a bad O2 sensor......Getting stuck low then stuck high.
If this was a hard short in the wiring.....It would be stuck Low or Stuck High at all times!!
I don't know this particular vehicle very well, However.......If the signal circuit was shorted to battery power......The O2 voltage reading in the data stream will read over 1.00vdc which is a voltage the 02 sensor itself cannot produce.
Do you have access to scan data?
Unplug it, hit with a little PB blaster, put a 7/8 box wrench on, start it up for just a minute, then hammer the other end of your wrench. She'll come.
Given the conflicting codes for the same sensor, I'd check it's connection and wiring first, then try a new sensor.
178K miles? I'd just change the upstream ones. I change mine at 80-100k miles as a maintenance item, cheap enough to do myself and prevents cooking a cat, if it goes out on a long trip.
Were it me , I would go ahead and buy a sensoe , then jack it up and check wiring . If wiring was OK , replace the old one .
Do not know how many O2 sensors the car has , but visually inspect all of them while you are under there .
Should just be two for an I4. Too busy this weekend to work on, not sure when I'll see the car again.
