So the last time my wife took our 2004 Odyssey to the local dealer to have the the ignition switch recall done, they offered a courtesy multi-point inspection. Well they found the CV boots on both left and right half axles were torn and leaking grease, plus some discoloration issues with all the fluids which I ignored since I know that fluids discolor over time.
A few months later I go change the oil and notice there is grease all over the oil pan, which wasn't there the last time I changed the oil. Upon further inspection I found grease slung all over the subframe and motor near the inner CV boots on both both axles. However, I did not see any obvious cracks in the rubber boots that would sling out the amount of grease that I saw; I was expecting some obvious cracks in the boots.
So I bought some new axles and proceeded to replace the failed ones. After removing the axles and inspecting them I could not find any cracks in the inner CV boots that went all the way through to the joint. I twisted and stretched the joints but could not find any cracks. There were some slight surface cracks in the rubber boots, but none that I thought would sling out as much grease as I had to clean off the subframe.
Is this a common dealer scam hoping to draw additional business? Anyone have a similar experience?
